Santa Fe timing belt
What should it cost to replace the timing belt in a 2005 Santa Fe. I'm in the suburbs of NYC.
I suppose it depends on whether you use a dealer's service dept.
or an independent mechanic. I had mine done at the dealership and it cost just about $600. I would think the labor rate where you live would be comparable to around here, so it should be in that ballpark. John |
Originally Posted by Chainmanor
(Post 33442)
2.4 - $$ 2.7 - $ 3.5 - $$$ -------------------------- 2.4 has a timing belt, a balance shaft belt, a tensioner, 2 drive belts 2.7 is the easiest to do, timing belt, 1 drive belt, and a tensioner 3.5 is a whole lot of fun, tight quarters, timing belt, 4 cams to deal with, tensioner, 2 drive belts, and a pile of labor.. Come Monday, I can rough our prices for you.. |
