Santa Fe timing belt
Old Dec 9, 2010 | 05:59 PM
Chainmanor's Avatar
Default Santa Fe timing belt
What should it cost to replace the timing belt in a 2005 Santa Fe. I'm in the suburbs of NYC.
Old Dec 10, 2010 | 06:40 PM
kerryman71's Avatar
I suppose it depends on whether you use a dealer's service dept.
or an independent mechanic. I had mine done at the dealership and
it cost just about $600. I would think the labor rate where you live
would be comparable to around here, so it should be in that ballpark.
John
Old Dec 10, 2010 | 09:37 PM
2005 with which engine ??
2.4 - $$
2.7 - $
3.5 - $$$
2.4 has a timing belt, a balance shaft belt, a tensioner, 2 drive belts
2.7 is the easiest to do, timing belt, 1 drive belt, and a tensioner
3.5 is a whole lot of fun, tight quarters, timing belt, 4 cams to deal with, tensioner, 2 drive belts, and a pile of labor..
Come Monday, I can rough our prices for you..
Robin Hood
Mar 14, 2022 02:24 AM
xjdubber
Mar 2, 2018 12:30 PM
mevin69
Nov 6, 2011 03:14 AM
Rhondas
Nov 1, 2008 02:48 PM
Rhondas
Oct 15, 2008 07:09 PM
