Smart Cruise Control, anyway to enable it?
Hi, I have the Santa Fe 2019, it does have the hardware for the Smart Cruise Control (I think it's the same hardware for Forward Collision too right?)
but sadly it's not enabled here in the middle east, many cars has it, so it's not a regulation issue, but the Santa Fe doesn't for some reason. but since the hardware is already installed (I think) then it should be possible to enable it to work.. right? is there a way? I was using Lexus GS before and I had a Software that I can customize most hidden settings for my car, is there anything similar? the dealer won't help ofc. Thanks |
Check your owner’s manual, specifically the fuse box description....there may be only one fuse designated for the active cruise feature, and Hyundai may have just deleted that one fuse in order to disable it.....that would be too easy, right? There’s probably more to it, but that is where I’d start.........
Originally Posted by SFUltimate
(Post 56123)
I still think it's software related issue, I need a software that enables hidden features in the car, did that before, I think it will do here too. or maybe I'm wrong, and the Forward Collision isn't the same hardware as the Smart Cruise Control, and I need to buy/replace mine to be able to use Smart Cruise Control. if they sell it anyway... |
Well, it was worth a post and a try, right? A software reflash with the programming for active cruise is probably going to be needed....I wonder if a Hyundai dealer here in the US could legally send you one on a flash drive. What country are you in, and why doesn’t Hyundai offer this feature there?
(Post 56125)
I'm from Saudi Arabia, and the why, I have no idea, all Genesis cars here has it, I think they are trying to give more features to Genesis cars, so they did not include this feature in any Hyundai car. I doubt that it will be legal to send it to a different country, that's why I'm looking around hoping I could find software/app or anything that could help. I do take the highway a lot, and the Smart Cruise Control would be great. |
I’v got a great relationship with my service department here.....I’ll check with them on Monday when they open and see if they’ve heard anything about this issue — I’ll let you know.........
(Post 56127)
best regards |
Sometimes some features can be enabled/disabled with a quality scan tool under the heading of special functions provided that feature is available on your vehicle.
Originally Posted by hanky
(Post 56140)
It depends on how much you want to spend. The general range is from $1500+ to $4,000 dollars. That is one reason why diagnostics are so expensive.
Code readers are a dime a dozen , but are very limited as to what other things they can do. |
