won't start
Old Apr 25, 2011 | 07:10 PM
bookie2874's Avatar
Red face won't start
My 2004 santa fe won't start turn key nothing.. The auto store told me it was my crank relay still won't start. Help please
Old Apr 26, 2011 | 09:09 PM
Dead battery ? Good clean ground connect...
Probe solenoid wire for source voltage when key turned to "start" position --> bum solenoid/starter.. not very often, but maybe see 1 every other yr.
Old May 20, 2011 | 12:17 PM
tiburonherb's Avatar
Default what did you mean by this?
My tib has erratic starting (meaning if I hit the clutch pedal a time or two it would 'catch') Battery is new, ground wire has continuity.
Did you mean bum terminal wire going to starter or bum starter solenoid?
I am trying to check that now, because it wont start at all now.
Old May 20, 2011 | 01:00 PM
Check the switch on the clutch that doesn't allows the starter to run unless the clutch is in.
Old May 24, 2011 | 08:25 PM
Thank you. I checked the continunity previously and it registered but I then took the switch totally apart and filed down any rough parts on the copper and she works like a charm now! Again, thanx!
Old May 25, 2011 | 09:43 AM
Nice work!
sipos
Feb 1, 2011 07:45 AM
Hatdrawn
Apr 27, 2010 08:49 PM
D_nice
Dec 4, 2005 07:36 PM
virtual231
Oct 26, 2005 01:04 AM
gnzlztwice
Aug 2, 2005 01:26 PM
