03 Sonata runs rough
Old Oct 30, 2013 | 01:12 PM
bartman's Avatar
Default 03 Sonata runs rough
I have an 03 Sonata 4 cy with 230,000 on it. Recently had a timing belt fail. I replace the timing belt, counter balance belt, water pump, 4 valves and all of the lifters. Car starts right up, no dashboard lights, and gas milage is fine. Car runs very rough, with a lot of vibration. Engine mounts seem to be fine.
Any thought??
Old Oct 30, 2013 | 04:54 PM
Do you have the vibration when the vehicle is running in park or only when moving?
Old Oct 30, 2013 | 05:58 PM
bartman's Avatar
A little of both, start up cold rough than smooths out once warmed up. when driving it is rougher and a bit nosiy. seems to be coming from the general area near the belts
Old Nov 7, 2013 | 09:14 AM
bartman's Avatar
Default Cure
After reviewing the service manuala and finding a great video on youtube I found the route to my problem. The oil pump sproket works off of its own balance at a 3 to 1 ratio. There is a gravity trick you can do to see if it's in the right place as well as a bolt that can be removed by the exhaust manifold to check if it is indeed correct. The engines purr's like a kitten with no vibrations.
paulwilliamson
Jun 14, 2024 06:36 PM
kvnfrank
Nov 14, 2013 06:21 AM
KAT
May 14, 2008 06:34 AM
sjl2962
Dec 8, 2006 12:26 PM
