05 - Electrical issues - Dash flickers, other components don't work
I'm having electrical issues with my 2005 Sonata and I'm hopeful someone has some ideas.
The issue sounds similar to the following post. I looked at fuses #24 - #30 and didn't see any that were blown. All appeared to be intact.
2005 Sonata Electrical Problem - Hyundai Forums : Hyundai Forum
I've recently replaced the battery.
I made a video of the issue:
Any ideas?
- The interior dome lights don't work
- The antenna does not work
- The dash and clock flicker if the radio is turned off while the headlights are on
- Headlights must be on
- If radio is powered off, the panel flickers
- If the driver door is opened, the flickers will stop
- Flickers will quit if the lights are turned off
Any ideas?
The flicker seems to mimic the turn signal
But, it is impossible to figure out without an electrical diagram/schematic
And actually being there to be able to run a few tests
Hope you find the problem and post back here what it was
Thanks
Thanks
