15 limited left side lights keep going off, turn off car will come back on sometimes.
The left side LED Front lights and all the back left side lights won't come on sometimes. I can restart the car and they will come back on. The back tail lights include the left side license plate light, all lights on the left. Please help! The front headlight always works but not the LED.
The lights are control by relays
One relay for the right side One relay for the left side I would investigate the relays Either replace or swap the relays to see if that makes any difference |
Yea that wouldn't be the case if they still come on and the headlight and blinker are still working. Usually goes out when I make a stop..
It is fine if you still want to hang onto your beliefs.
Me, I usually check things out anyway, especially if it is only swapping relays. After checking the relays, would suspect the wiring Good luck |
I'm sorry I just had someone tell me it was connections. So is it easy to check the relays? You are correct wise choice.
It's a 2015 I shouldn't have these problems. It is out of warranty, literally just went out of it. So I'm just really upset. Thank you for your response
2015 sonata limited
Originally Posted by avisitor
(Post 55909)
