15 limited left side lights keep going off, turn off car will come back on sometimes.
Old Mar 26, 2019 | 12:49 PM
Hbrooke86's Avatar
Default 15 limited left side lights keep going off, turn off car will come back on sometimes.
The left side LED Front lights and all the back left side lights won't come on sometimes. I can restart the car and they will come back on. The back tail lights include the left side license plate light, all lights on the left. Please help! The front headlight always works but not the LED.
Old Mar 26, 2019 | 06:11 PM
avisitor's Avatar
The lights are control by relays
One relay for the right side
One relay for the left side
I would investigate the relays
Either replace or swap the relays to see if that makes any difference
Old Mar 26, 2019 | 07:23 PM
Hbrooke86's Avatar
Yea that wouldn't be the case if they still come on and the headlight and blinker are still working. Usually goes out when I make a stop..
Old Mar 27, 2019 | 01:54 PM
avisitor's Avatar
It is fine if you still want to hang onto your beliefs.
Me, I usually check things out anyway, especially if it is only swapping relays.
After checking the relays, would suspect the wiring
Good luck
Old Mar 27, 2019 | 08:16 PM
Hbrooke86's Avatar
I'm sorry I just had someone tell me it was connections. So is it easy to check the relays? You are correct wise choice.
Old Mar 27, 2019 | 08:32 PM
Hbrooke86's Avatar
It's a 2015 I shouldn't have these problems. It is out of warranty, literally just went out of it. So I'm just really upset. Thank you for your response
Old Mar 28, 2019 | 02:14 AM
Hbrooke86's Avatar
Default 2015 sonata limited
Good luck
Thanks for your input, it is greatly appreciated
daniel2229
Apr 25, 2016 01:52 AM
ibbarker69
May 26, 2007 08:42 PM
Majki
Jan 8, 2007 06:21 PM
sc123456
Nov 2, 2005 07:21 PM
CTtiburon2004
Jul 25, 2005 06:43 PM
