lights problem
Old May 23, 2007 | 06:11 AM
ibbarker69's Avatar
Default lights problem
first hi all new here and hope you can all help me
wifes 2002 santafe lights don't work
no fog lights head lights or highbeams
high beams work when you pull them back like that flick thing if you know what i mean
have checked all fuses all ok
don't know what to do any help?
thanx
Old May 24, 2007 | 03:23 AM
gatorwv's Avatar
Default RE: lights problem
i believe there may be a circuit breaker for those..........gheck in your owners manual..........should be in same chapter as fuses, etc
Old May 24, 2007 | 10:30 AM
Doohickie's Avatar
Your passenger compartment junction block should be near your left knee, probably behind a panel, door, or bin (sorry, I'm not familiar with the Santa Fe). Anyway, if the flash-to-pass is working but nothing else is, your problem is most likely the headlamp relay fuse (Fuse 5 in the passenger compartment junction block, a 10 Amp fuse), the headlamp relay (which is on the other side of the junction block), or the wires running to or from these. If none of those, it might be the switch itself.
I'm attaching some images that may help you.
The headlight schematic diagram. If Flash To Pass is working, the right side is okay; the problem is on the left side of the diagram.
[IMG]local://upfiles/1133/EA7773901C8945139C39CD8105168C24.jpg[/IMG]
Location of the passenger compartment junction block (fuses are toward the bottom I think)
[IMG]local://upfiles/1133/120E7A42ACA14C908435758D2132F68D.jpg[/IMG]
Junction block map & fust list
[IMG]local://upfiles/1133/13A5208F1FAD496DB890FF1057F934CD.jpg[/IMG] [IMG]local://upfiles/1133/556581C3DC884349B6B716C6D0C721C5.jpg[/IMG]
Old May 26, 2007 | 07:57 AM
ibbarker69's Avatar
thank you so much for the info
after some figuring how to get my big hand behind there i swapped out the the
head light relay and the tail relay and wala lights
going to store now to get the relay
thank you so much
Old May 26, 2007 | 08:42 PM
Doohickie's Avatar
w00t! I'm always both happy and amazed when my advice helps!
psychodoodbrij92
Mar 28, 2019 11:54 AM
ronnieoverholser
May 12, 2013 08:57 PM
Verminator
Sep 14, 2011 01:03 AM
DOH
Jan 20, 2009 07:47 PM
Stujak
Apr 7, 2008 06:58 AM
