1998 sonata
Old Sep 26, 2005 | 12:43 AM
cstonekk92's Avatar
Default 1998 sonata
i have a problem with my sonata idleing. at first it started dying when i turned the airconditioner on at idle. now it dies as soon as you let off the gas. the problem with fixing it is it could be so many things and all those different things cost so freaking much you might as well get a new vehicle. so any suggestions as to what the problem could be would be helpful. also i had the transmission checked and the only code they could find was that cylinder 3 wasn't firing. the plugs and wires are good. any relation to the above problem and maybe suggestions on how to fix it. thanks
Old Sep 28, 2005 | 11:02 PM
duke's Avatar
Default RE: 1998 sonata
have a dealer check out the idle stepper-motor.
Old Nov 6, 2011 | 04:11 AM
lorrie's Avatar
check the power transmitter that fires the coils....that normally seems to be the issue..
dietcola
May 5, 2009 09:28 PM
Akstud1983
May 18, 2007 07:28 PM
jaynang_99
Mar 20, 2007 12:38 AM
jovance
Oct 2, 2006 04:33 PM
sparxx
Sep 22, 2005 07:10 PM
