2.4l timing belt or chain?>
Old Aug 10, 2008 | 09:31 PM
boilerman's Avatar
Default 2.4l timing belt or chain?>
i have the 2009 sonata 4cylinder just wondering if its a timing belt or chain -
Old Aug 11, 2008 | 06:50 AM
Default RE: 2.4l timing belt or chain?>
That's the Theta engine and it has a chain.
Old Aug 24, 2008 | 10:55 AM
01gtprocket's Avatar
i thought it was a timing belt... maybe i read it wrong in the owners manual says change every 60k. am i wrong?
my car is a 2001 snonta 2.4 dohc
Old Aug 24, 2008 | 11:38 AM
ken99's Avatar
You are not wrong about your 2001 Sonata having a timing belt that pereiodically needs to be serviced. The 2.4 liter 4 cylinder engine in your 2001 Sonata is not the same 2.4 liter engine found in the latest generation of the car. I beleive your engine was called the "Sirius", which is a cast iron/aluminum block design that does employ a timing belt that does need to be replaced every 60,000 miles. I beleive the Sirius was the ultimate and last design of this type of engine they had use for 20+ years.
[IMG]local://upfiles/4972/73E790633ACA4DC29898E7600C128137.gif[/IMG]
With the 2006 Sonata, Hyundai switch to a newer, more modern design 2.4 liter engine. The engine in the 2009 Sonota is called the "Theta II", an aluminum block and head design that uses a silent timing chain system developed by BorgWarner. The chain system is designed to last the life of the engine.
[IMG]local://upfiles/4972/B96E32215A824551AD7E6F3B64981EFB.gif[/IMG]
Old Aug 24, 2008 | 11:42 AM
what i read in 2005 is when they went to timing chain.. I read alot ...
better for the consumer..
mychee
Jan 30, 2020 11:25 AM
pizzaman
Aug 12, 2012 08:53 PM
JACK M
Sep 26, 2011 07:23 AM
mackdiesel
Aug 8, 2010 09:20 PM
rkmullins
Feb 7, 2008 02:13 AM
