2001 gls - p0118 & clearing codes question
Getting code p0118 - no others.
Common solution seems to be to change the coolant sensor. Hooked up scanner with cold engine - temp read 120. Ran it for a bit and read a temp of -40. RPM's also bounce around. Could the problem be more than the sensor? Thanks, Joe |
Replace the sensor, you know the values is incorrect..
Got myself caught up in DIY overthink...
Changed the sensor - no trouble code. Funny thing though, it is a 2001 (checked the VIN number), but the sensor was 2000. I thought only some European cars did the keep using last years parts til they run out stuff? |
