2003 Sonata Leaking Oil
Old Sep 1, 2010 | 11:59 AM
bj_otto's Avatar
Default 2003 Sonata Leaking Oil
Recently we had replaced the Camshaft and crankshaft sensor. The car has always used some oil, but after those were replaced it was leaking a lot of oil. I replaced the valve cover gasket and that helped, but I'm still using oil. I can smell the oil when I stop at a stop light, but it doesn't seem to leave any puddles. Is there a common part that leaks oil on the Sonatas. I don't see oil on top of the engine anywhere. Any suggestions would be greatly appreciated.
Old Sep 1, 2010 | 12:27 PM
rallyman's Avatar
Sounds like one of the sensors was not installed properly. I'm not sure the crank sensor is in a lubricated part of the engine but I know the camshaft position sensor is. If there is an O-ring that is not installed or not seated properly you may be losing oil there. Since the issue got noticeably worse at that time that's where I would be looking. The oil would likely come out mainly when the engine is running and would burn up on hot engine parts.
Old Sep 1, 2010 | 01:24 PM
Which engine ??
(2) applicable engine to the Sonata ...
Old Sep 1, 2010 | 03:12 PM
bj_otto's Avatar
4 cyl engine. Forgot to add that.
stokelife
Nov 24, 2019 06:16 AM
lkbolles
Oct 2, 2014 04:03 AM
semza
Mar 18, 2012 02:47 AM
Rhanck
Sep 4, 2011 08:07 PM
BobMcLean
Dec 18, 2005 03:52 PM
