2005 Sonata Low Beam Replacement
One of my low-beam bulbs burned out, and I can't get to it with the windshield washer fluid storage located smack dab in front of it. Does anybody know how to change it? Do you have to unscrew the screws and pull the entire front light out? I can't fit my hand between the wiper storage and the cap screw to replace the bulb.
I'm sure this is a novice questionto the masses, so please, your help is much appreciated.
I removed my windshield washer container to get to my headlight bulb on my 2031 Sonata and it gave me the access I needed to replace the bulb. Sometimes, you just have to remove stuff to get to whatever you need.
