2007 & 2008 Rear Brake Problem ?
Wondering if anyone else has experienced this ? I'd posted in July about the 'need' (?) to replace the rear brakes on my '07 GLS at 18,600 mi...I know
. We began to hear the tell-tale metalic squeel primarily when turning the steering wheek to the right. Took it in and the mechanic and service guy indicated that the rears were worn down, mainly on the left. Being that I was hearing the noise too, which I knew to be the wear indicators and that my 19 yr old was driving the car mainly to her Summer job, I decided to have them replaced and the rotors turned. Since I'd had the car for 18 months there was little hope of having them replace under warranty. Between this and the 2 other Hyundai sites, I found a few other posts about this problem which seemed to indicate that in fact it might be a caliper or piston or rear pad issue needing an adjustment.
Today I took my '08 GLS, in service 8/15 last yr., in for the 34 point inspection, thanks HMC for the freebie coupon - and asked that they specifically check the brakes. Well...they found that the "rear brakes were sticking in slides causing glazing" they "freed the pads and machined the rotors" this time on the house
I insisted again that this wasn't normal especially for rear brakes and that there was some chatter on the internet message boards about what the problem might be.
The service guy, who seems to be a genuinely decent sort pulled up the brake job on the '07 from July, printed it out and offered to discuss the problem with the
RSM who comes in periodically to see what they "can do for me" I made sure to reiterate that I have 2 Sonatas and not just a 10 yr old Accent! He did acknowledge that the wear war on the low side of normal, I told him that he needs to look up to see the low side of normal for rear brakes.
So - has anyone experiences anything like this from either of these years ? or have another idea of what might be going on here ? On both cars the driving as about 75/25 city/hwy the 08 is garaged the 07 outside and I'm in W. PA w/4 season weather if it matters. We like both cars but this has me concerned.
mtbrain3343
May 21, 2012 02:30 PM
Rhanck
Sep 3, 2011 07:41 PM
JohnKyriakos
Dec 31, 2008 11:12 AM
JohnKyriakos
Feb 20, 2008 02:38 AM
