2007 SE - Wheel size options (snow tires)
Old Oct 1, 2010 | 09:07 PM
  #11
rmissourimule's Avatar
The steel wheels from the GLS will work just fine with the stock tire size. If you measure the outside diameter it will be exactly the same at 80 inches. I replaced the original GLS steel wheels and tires on my 2009 Sonata with a set of Limited wheels I purchased off ebay. Works just fine. The profile is 55 instead of 60 but the circumference is the same which is all that matters.
As to whether the TPMS can't be programmed for more than four wheels, I tend to doubt this. I have a fifth Limited wheel with TPMS which also works so I have five in all. I got it because if I picked up any more nails and had to have a tire repair I didn't want to drive around with that stupid looking mini spare. I have three other original sensors which will also work should I ever need them I removed from the original steel wheels. Now if I could only get rid of those wheels taking up space in my shed. May put them out for the junk man.
Old Oct 3, 2010 | 04:17 PM
  #12
WOW! I thought 24" wheels were big bit 80" diameter wheels! That's amazing. Do you need a ladder to get in your car?
Hyundai cars can only have 4 TPMS sensors programmed. Not 8 not 5. Yes, if you get a flat and put on the spare (the spare does not have a sensor) the TPMS light will still be on until you fix the flat tire.
bsgarner
Jun 3, 2011 05:47 AM
jholicky
Nov 25, 2008 11:31 AM
WVUguy
Nov 4, 2007 04:30 PM
arkayllb
Jan 15, 2007 02:41 PM
2loud2k2xd
Mar 18, 2006 07:39 PM
