2011 Sonata
How many miles are on it? The engine needs to break-in and loosen up. Mileage will get better but it also depends on driving style. City, hilly and heavy throttle driving will lower MPG as will A/C usage.
it has 1600 miles. I understand it depends on lot of factors, but not even 21 MPG seems a bit too low...and on top of that is my wife who id driving it, and I know she wont drive crazy.
Therefore just wondering what other ppl have for the MPG. Can they get anything close to 35 MPG at all???
But she will have the A/C on for the trip home. That will lower MPG. First I'd check the tire pressures and then check the ethanol content of the gasoline you use. Gas with 10% ethanol will give lower fuel economy (about 3%) due to having about 35% less energy per unit volume. Also, how are you getting your MPG numbers? Are you basing it off the trip conmputer or calculating it manually? Do you fill the tank the same way every time?
I average 29-30 daily driving. Keep in mind that my daily commute is a pretty straight, flat road with a 55 mph limit. On my interstate driving, I average between 34-36 and that was with my Sonata loaded down (moving).
Also, for real city driving, I was avg. around 25 mpg.
2011 sonata - 1800 miles.
errysherali
Nov 12, 2010 06:45 AM
