2011 Sonata Limited 2.0t Cabin Air Filter
Old Aug 19, 2011 | 06:15 PM
sizz's Avatar
Default 2011 Sonata Limited 2.0t Cabin Air Filter
Has anyone changed their cabin air filter yet? Where is it located and how do you access it to change it? The dealer want's $65.00 to change it. I rather do it my self.
Old Aug 20, 2011 | 11:29 AM
1. Disconnect the damper (B) from the glove box (A).
2. Disconnect the glove box lift (C).
3. Remove the filter cover (A) with pushing the ****.
4. Replace the air filter (B), install it after making sure of the direction of air filter.
In case of driving in an air-polluted area or rugged terrain, check and replace the air filter as frequently as possible.
5. Installation is the reverse order of removal.
Old Apr 7, 2012 | 11:07 AM
maratz's Avatar
Sweet instructions, THANK YOU! Gives me confidence to try it myself!
Old Apr 11, 2012 | 02:53 PM
LESAN49's Avatar
Default Air filter replacements
Found the exact replacement for both the air filter and the cabin air filter at the local Pep Boys. Purolator brand withexactly the same specifications as the original for one third of the dealer price.
Old Apr 12, 2012 | 11:11 AM
cwoptima11's Avatar
This is the same as the Optima and was REALLY easy to do!
Old Apr 15, 2012 | 08:05 PM
Johnzz1420's Avatar
Damn, such a simple, simple fix. How can a dealer charge $65.00 to customers for this job??? That's absurd!
Old Apr 16, 2012 | 11:45 AM
maratz's Avatar
Sucks but standard dealer labor rate is expensive.
Luckily, thanks to these instructions I did it myself too! -
Old Apr 22, 2012 | 11:02 AM
Boxer19's Avatar
Question Cabin Air Filter
Does anyone know if the arrow aims up or down, I neglected to notice when I removed the old one?
Old Apr 22, 2012 | 03:03 PM
Look at the arrow on the old filter. The side with all the dirt and debris will be on top. So hold the old filter with the dirt side up and look at the arrow.
Old Jun 15, 2012 | 11:53 AM
seanbear's Avatar
Default Amazon
I just got one on Amazon for $12.80. Takes 2.5 minutes to replace. Free shipping on orders of $25 so just get something else you need too.
