2018 Sonata, Key Fob replacement
Old Mar 2, 2020 | 10:53 AM
Jayre's Avatar
Default 2018 Sonata, Key Fob replacement
Daughter lost one of the key fobs. Called the Stealership and was told it'd cost $550 for a new one!!
I see used key fobs online for under $50 and there are plenty of locksmiths who can program. So I bought one. It looks the same on the outside but inside looks different and the model # reads 95440-D3100 which seems to be for Sante Fe. Would this work on Sonata or does it have to be model specific? Upon research, the correct model # for sonata key fob is 95440-C1500NNA.
Old Mar 5, 2020 | 04:33 PM
What if you took it to the locksmith and have him try to program it. If it works , all is well if not ,maybe he can better answer what could be the problem.
Old Mar 7, 2020 | 08:33 PM
Soccerguy's Avatar
The Sonata has a trunk, where as the Santa Fe has a hatch. I am not sure if this different key fob model will actually work? Try to purchase the correct smart key fob yourself, and then take it to a professional locksmith. This way it will be much cheaper than using the stealership.
Old Jan 16, 2021 | 11:35 AM
AllfordWard's Avatar
You can't program it on your own, you need to take help from locksmith experts to program it.
Old Jan 16, 2021 | 12:34 PM
One of the reasons we recommend a certified locksmith is they need to have special clearance to access certain anti theft (immobilizer) info from the manufacturer's website.
Different vehicles have different requirements to program keys and/or key FOBs. Special equipment is necessary and certain conditions must be met to program addl FOBs
Some can be easily programmed by the vehicle owner providing certain conditions are met. What does your owner's manual say in this regard?
Old Mar 20, 2021 | 08:43 AM
EuwingKelly1's Avatar
Yes, they have special clearance to access anti theft information from the manufacturer website, this is the reason i also recommend locksmith dc for key fob replacement.
staggwru
Nov 8, 2019 11:13 AM
Chet57
Nov 15, 2012 08:01 AM
btpena
Mar 25, 2012 11:23 PM
sonata02
Aug 20, 2011 06:34 PM
mjb457
Dec 22, 2010 09:16 AM
