Any problems with Digital Dash Clock?
Old Jul 19, 2006 | 06:22 PM
steelergalwv's Avatar
Default Any problems with Digital Dash Clock?
I just got a 2004 Sonata. The Dash Clock will not stay set. The battery is good has anyone else had this problem? Does anyone have any suggestion on how to fix the problem? It bugs me that the clock is centralized and it always has the wrong time!! Please help if you can.
Old Jul 31, 2006 | 10:30 PM
KabukiDreamBoy's Avatar
Default RE: Any problems with Digital Dash Clock?
might possibly be a fuse issue though not certain...worth checking though as a first resort.
Old Jan 18, 2007 | 04:16 AM
sonataz's Avatar
I am having this problem too, have you solve your problems. Can you tell me if you known what was wrong?
Cheers
sonataz
Old Jan 18, 2007 | 12:36 PM
I can only suggest checking the fuses as a first resort otherwise it might be a faulty clock unit though that seems unlikely.
Old Jan 20, 2007 | 08:03 PM
GOLD07's Avatar
FUSES WORK OR DONT WORK.HOW OLD IS YOUR BATTERY? I HEAR WHEN BATTERY IS GETTING WEAK THE CLOCK AND OTHER THING ACT UP >
Old Aug 20, 2011 | 12:35 PM
jandjvideo's Avatar
Same thing with the dash clock here in Florida. I agree that it's probably NOT a fuse. The battery sounds like a probable cause. Does the car have some sort of separate circuit to feed the clock? It must be a very low voltage circuit to run the clock.
Old Nov 16, 2011 | 05:10 AM
janetmcq's Avatar
I just bought a used 2010 Sonata. There is an "OFF" light that is lit next to the digital clock display. I do not know what this means or how to turn it off. Can anyone help? Thanks.
Old Nov 16, 2011 | 06:59 AM
Did you get an owners manual with the car?
Have you read it?
That light is for the passenger side air bag. See the writing above the light that says "PASS AIR BAG"? There's a sensor in the seat that senses weight. If the seat is unoccupied or when you have a small child in the seat that doesn't weigh enough, the sensor turns off the passenger air bag so it won't deploy in an accident. If an heavier passenger (adult) sits in the seat the light will go out.
Attached Thumbnails  Any problems with Digital Dash Clock?-2010-sonata-1-42.jpg
Old Nov 17, 2011 | 05:14 AM
janetmcq's Avatar
Default Passenger Air Bag Sensor Light
Thank you NovaResource. Yes, I had searched through the manual before posting the question. My daughter was sitting in the passenger seat when it happened the first time, but she does weigh right under 100 lbs. Maybe that was too light? Anyway the car dealer explained everything to me. This is my first car since I bought a 1999 Mazda 626...A lot has changed since then! Thank you for your time.
Old Nov 17, 2011 | 06:50 AM
While having a child in the front seat is usually not a good idea, these sensors can turn off the air bag so they aren't killed by an opening air bag in the even of an accident. I would suggest keeping childern in the back seat whenever possible.
Bobcag
Mar 12, 2012 10:09 AM
HUSKERFAN
Jan 29, 2007 02:02 AM
HUSKERFAN
Jan 22, 2007 01:45 AM
msvg
Jul 19, 2006 06:25 PM
steelergalwv
Jul 18, 2006 11:31 PM
