Automatic Climate Control (2009) Question
Old Jun 15, 2009 | 11:51 PM
J-Man's Avatar
Default Automatic Climate Control (2009) Question
With respect to the heating/AC system with automatic climate control, I'm confused about something. I like to use the system without the heat or AC on-- in other words, just the fan without any added heat or cooling. It seems like you should be able to do this with the system; however, for some reason when I take it off of AUTO and just turn the fan on (without pressing the AC button), the target internal temperature that's used by the automatic system shows up on the screen. I can't tell if this is having any effect on the incoming air or not.
Another thing that's confusing is that it seems like when the system is in AUTO mode, and the AC is being used to cool the interior down to the target temperature, the AC light is not lit. It seems like it only goes on when it's invoked manually.
Old Jun 16, 2009 | 12:14 AM
TheWidowsSon's Avatar
Good questions. I've been wondering the same thing.....
Old Jul 15, 2011 | 07:56 PM
charby's Avatar
I find if the vehicle is started on the fan setting it is OK. but once you make changes it goes to heat or cool. Had it for a year and still stumped on system.
Old Jul 15, 2011 | 08:20 PM
Have you read the owners manual?
Old Jul 16, 2011 | 07:44 AM
charby's Avatar
No, that is a good place to start. I saw other threads after post that the A/C is pushed 2 times after AUTO is set to cancel and run fan only. I'll try that. Has worked on fan before but not sure how that was happening.
Thanks to this site, I avoided the manual
zero10
Mar 24, 2010 03:45 PM
ab3
Jul 27, 2009 03:26 PM
neomatrix
Mar 8, 2009 06:02 AM
faheyk1981
Apr 21, 2008 10:40 AM
belunt
Apr 15, 2006 05:26 PM
