changed oil in 05 sonata and there is nothing on the stick when i check the level???
Old Feb 25, 2011 | 11:32 PM
04prixgt04's Avatar
Default changed oil in 05 sonata and there is nothing on the stick when i check the level???
I changed the oil and the filter today. let it drip for 15-20 minutes. put 4.8 quarts in (book says 4.77 but oh well) and checked the level. there is nothing on the dip stick. drove it around the block check again natta. nothing. It's the v6 and has 16,800 miles. got it from an old lady whos husband died and she had the maintanence papers on it . it was changed on time every time. what should i do? im not getting an oil light and she seams to be driving fine.
Old Feb 26, 2011 | 07:03 AM
1. are you sure the dipstick is all the way down?
2. are you sure there is no oil on the stick? New oil is so clean it's almost clear and hard to see.
Old Feb 26, 2011 | 11:11 PM
04prixgt04's Avatar
yes the dip stick is all the way down and i was thinking the same thing about just not being able to see it. especially since it only has 16,500. ive put about 150 miles on it since. ill check it again in the morning.
Old Jul 10, 2011 | 10:44 AM
Paul 4546's Avatar
Default Dip stick error
I have the opposite problem. I have a 2008 Azera Limited 3.8L
Doesn't matter if I get an oil change at the dealer or do it myself and put in the correct 5 1/2 quarts, the dip stick always shows 1/2 quart too much. Checked with parts dept and it is the correct dip stick. Its been the same for all Azera models. Weird to say the least.
TerryMSU
May 11, 2015 04:03 PM
HighLifer
Mar 12, 2015 06:39 AM
shabdxb
Nov 16, 2011 02:51 AM
mitchkam1
Apr 20, 2010 10:21 PM
drm819
Jan 9, 2008 04:05 PM
