Console shifter light
The year on the car is 2004 and the light(LED?) under the console to the left of the shifter(P,R,N,D) is burned out or a loose wire. How do you access the bulb?
Remove console panels enough to access bulb-socket -
1.Pry the rear upper cover from the floor console with a flat-tip screwdriver. http://www.hmaservice.com/data/Passe...G/ksab111b.gif 2.Remove the front upper cover from the floor console after removing 2 screws. http://www.hmaservice.com/data/Passe...G/ksab155a.gif 3.Remove the floor console mounting screws (2EA) and bolts (2EA). http://www.hmaservice.com/data/Passe...G/ksab111c.gif 4.Remove the floor console assembly after removing 4 screws. http://www.hmaservice.com/data/Passe...G/ksab155b.gif 5.Installation is the reverse of removal. |
