Gearbox Oil Change Question ??
Old Feb 24, 2006 | 11:12 PM
sonnyboy's Avatar
Default Gearbox Oil Change Question ??
Hi, I have a 98 Sonata (Manual)
Want to drain and refill the gearbox.
Can someone kindly explain just where the drain and refill plugs are?
I have looked under the car and all I can see is a large (24mm) bolt or plug right at the back - is this the drain?
It's damn hard to get to and won't take a socket as its too close to the frame.
Is the fill plug the one on the small steel plate right at the front.
Looking at it I can't see how it can hold 2.5 litres if these the correct plugs.
Any help much appreciated.
(Don't have a service manual - just a CD - not much help)
Sonny
Old Aug 18, 2008 | 11:15 AM
xucaen's Avatar
Default RE: Gearbox Oil Change Question ??
I have a 2000 Hyundai Accent, 5 speed standard. Reverse is completely gone. should I add oil to the gear box? how do I do that?
Old Aug 18, 2008 | 11:31 AM
If reverse is "completely gone", adding oil will not fix your problem. Take it to a transmission mechanic.
Also, if you have an Accent, why did you post this question in a Sonata forum? Plus, there is no need to post the same question 4 times in 4 different forums.
Rod11
Nov 3, 2010 08:38 AM
arb
Jul 11, 2009 07:40 AM
danieleonharper
Nov 15, 2008 01:36 PM
00 Elantra
Aug 18, 2008 11:17 AM
just a little woman
Aug 18, 2008 11:16 AM
