Heating problem 05 Sonata
Old Feb 21, 2007 | 01:00 PM
rw02kr43's Avatar
Default Heating problem 05 Sonata
My g/f has a 05 Hyundai sonata. When running the heater it's warm air coming out of all vents except the passenger side by the window. It blows out cold air.what could cause this? I thought they all came from the same heater.
Jason
Old Feb 21, 2007 | 02:25 PM
fritz's Avatar
Default RE: Heating problem 05 Sonata
yes, the heat source, heater core, is the same. I suspect either the cable or vacuum tube that directs and actuates the louver directionis at fault. The fix may as simple as moving the lever back and forth a few times to free the louver. otheriwse you need to check the ductwork and/or thatthe louver is binding preventingthe directed heated air from reaching the vent.
maabel
Mar 30, 2009 12:39 AM
dsrming13
Nov 12, 2008 11:39 AM
barns123
Jan 22, 2008 09:49 PM
augu.stas
Nov 6, 2007 08:15 PM
alanh
Feb 4, 2005 11:46 AM
