WIX 57061 Oil Filter VS. Hyundai Oil Filter
Old 10-24-2007, 10:17 AM
valleydavid's Avatar
Default WIX 57061 Oil Filter VS. Hyundai Oil Filter
I'm an Amsoil dealer and they are selling WIX 57061 Oil Filterfor my 2006 LX Sonata. I'm using Amsoil Synthetic 5W-20 with a 7500 mile change interval. I have been using the Hyundai filter. Any pro's/Con's to using the WIX with this type of interval? Can I expect same type or better performance from a WIX filter?
Old 10-25-2007, 08:01 AM
Doohickie's Avatar
Default RE: WIX 57061 Oil Filter VS. Hyundai Oil Filter
That's the cartridge filter, right? I don't really know much about those.
For the standard screw-on base filters, there was an issue with aftermarket filters not having the correct specs which led to oil starvation. Most commonly it seemed that Fram was the culprit; the reputation for "good" aftermarket filters seemed to be that Wix and Purolator were okay.
In that case, though, I think it had more to do with the pressure of the bypass valve. Honda and Hyundai used the same screw-on base, and Honda has a higher trip point for the bypass valve, which means that if a Honda-spec filter was used on a Hyundai, it wouldn't bypass until a higher pressure than required and the engine would suffer damage from oil starvation.
I'm not sure how any of that applies to cartridge filters though.
Old 10-29-2007, 09:36 AM
greyhead's Avatar
I have been using an Amsoiloil filter on an 2000 Sonata for seven years and an 04 for four years with no problems. What I don't like is the small filters that most auto mfg's have gone to.
Old 10-29-2007, 10:54 AM
Doohickie's Avatar
Is the Amsoil filter larger than the Hyundai OEM filter? What are its dimensions?
Old 10-29-2007, 12:07 PM
greyhead's Avatar
Actually the filter demensions are the same. I checked them about four years ago when my daughter got the 04. Its possible to use a bigger diameter since the was adquate space. My 02 Grand Caravan uses the EAO96 as opossed to the EAO42 which is the same size as the OEM filter.
Paulus
03-11-2013 10:29 AM
Aggie_1990
01-17-2012 12:28 PM
mrmr256
12-08-2011 09:54 PM
thx1971
08-10-2009 07:47 AM
derek slang
05-18-2007 06:59 PM
Quick Reply: WIX 57061 Oil Filter VS. Hyundai Oil Filter
