How can I access gauges? 02 sonata
Old Dec 11, 2005 | 02:30 PM
cain's Avatar
Default How can I access gauges? 02 sonata
I have ordered a overlay to make my gauge face white. Does anyone know if the whole dash must be removed to get to the gauges or can I access them by removing the black plastic part? I have removed the three screws to the black plastic piece but it still does not come out.
Old Dec 28, 2005 | 05:08 AM
modus's Avatar
Default RE: How can I access gauges? 02 sonata
I have done this before. Take out the three screws from the plastic piece. That pops out. Use a flathead screwdriver or something to pry it from the bottom. There will be four more screws to get the actual guage cluster out. unscrew those and pull it out, disconnect the wires, and then the clear plastic piece can come off. the needles from the rpm, speedo, gas and temp guages just pull off. take off the 'stock' piece and replace with the one you got and then put everything back together. have fun...
Old Oct 8, 2011 | 04:34 PM
rocketsauce035's Avatar
I know this is old as dirt but this is exactly what I'm looking at doing.
So am I correct in assuming that the overlay makes the numbers green and not the lights themselves?
Doohickie
Apr 8, 2025 06:42 AM
som3aa
Sep 1, 2009 07:57 PM
tsh_98103
Aug 4, 2009 07:40 AM
aqhjr28
Sep 12, 2007 08:15 PM
BlackBullet
May 23, 2006 09:14 PM
