-   -   How do I change the auto trans. fluid on an '06 Sonata? (https://www.hyundaiforum.com/forum/hyundai-sonata-19/how-do-i-change-auto-trans-fluid-06-sonata-9425/)
mundo Oct 26, 2010 04:24 PM
Does the pan have to come off. Is there a filter and drain plug?
sbr711 Oct 26, 2010 07:08 PM
1 Attachment(s)
Remove the large drain plug from bottom of trans case (need 15/16 or 24mm).
Let drain, install plug (find the thin seal washer and make sure it get put back)
Add 4qt of HYUNDA/KIA 00232-19012 SP-III ATF.. let run and get real hot, inspect level with shifter in "N", add ATF slowly to bring level just to bottom of HOT zone on dipstick, test drive, verify oil level.
https://www.hyundaiforum.com/forum/a...1&d=1288138042
fritz Nov 16, 2010 11:33 AM
I read somewhere in this forum that this procedure will only partly remove the ATF and that to do it properly, one must flush out the connections at the radiator(?) Is this true
Sonny Jim Nov 16, 2010 12:24 PM
That is true of all automatic transmissions, yes.
Sbr711, is the procedure the same for the '11 Sonata (do they still have a drain plug)?
Sonny Jim Nov 16, 2010 03:53 PM
Nevermind. Asked my dealer today as I was in getting maintenance parts, and he says they do still have the drain plug.
