how do you know if you have abs
i have a 02 sonata with power sunoof there are fuses in the fuse boxes in the spot of abs but no light come on when i start the car
RE: how do you know if you have abs
If you have ESC, electronic stability control, you have antilock brakes.
If you have a light on the instrument panel that says ABS during the self test(when the oil, airbag, etc. lamps light)when you first start the engine, you have ABS. If you have multiple brake lines emerging from the master cylinder, you have ABS. If when you slam on brakes fast enough to skid, and you hear and feel the wheels go bump bump bump, you have ABS. |
no light come on when i start it up but i have fuses in the spot in the fuse box
ORIGINAL: czaka i have a 02 sonata with power sunoof there are fuses in the fuse boxes in the spot of abs but no light come on when i start the car http://www.hmaservice.com/data/Passe...G/eja9028a.gif |
I guess that's what I meant when I said master cylinder. It's easy to see though, with a bunch of metal hydraulic lines sprouting out of it.
