how do you know if you have abs
Old May 10, 2008 | 02:07 PM
czaka's Avatar
Default how do you know if you have abs
i have a 02 sonata with power sunoof there are fuses in the fuse boxes in the spot of abs but no light come on when i start the car
Old May 10, 2008 | 10:17 PM
RknRusty's Avatar
Default RE: how do you know if you have abs
If you have ESC, electronic stability control, you have antilock brakes.
If you have a light on the instrument panel that says ABS during the self test(when the oil, airbag, etc. lamps light)when you first start the engine, you have ABS.
If you have multiple brake lines emerging from the master cylinder, you have ABS.
If when you slam on brakes fast enough to skid, and you hear and feel the wheels go bump bump bump, you have ABS.
Old May 11, 2008 | 08:19 AM
czaka's Avatar
no light come on when i start it up but i have fuses in the spot in the fuse box
Old May 12, 2008 | 08:19 AM
ORIGINAL: czaka
Look for the HECU (Hydraulic and Electronic Control Unit) located on the passenger side of the engine compartment by the strut tower. There will be a bunch of brake lines running to the unit..
Old May 14, 2008 | 10:38 AM
RknRusty's Avatar
I guess that's what I meant when I said master cylinder. It's easy to see though, with a bunch of metal hydraulic lines sprouting out of it.
MannySarria
Jul 22, 2024 11:51 AM
puck1263
Oct 25, 2014 04:53 PM
Jon Hansen
Feb 18, 2012 09:54 PM
harmug
Jan 8, 2008 02:49 PM
lemony
Off Topic
Jul 26, 2007 08:33 PM
