How to remove the rotors on a 97 Hyundai Sonata?
Old Sep 26, 2009 | 06:48 PM
davidd31415's Avatar
Default How to remove the rotors on a 97 Hyundai Sonata?
Hello,
I just changed the front brake pads on my 97 Hyundai Sonata and found that one of the rotors needs to be changed. Do I need to remove the entire hub assembly to remove the rotor? The Haynes manual I own shows bolts holding the rotor to the hub. I've looked at the outer side of the rotor and stuck my head in the wheel well to get a look at the inner side and did not see these bolts in either case.
If I could loosen the carrier bolts I would remove the castle nut and remove the entire assembly but unfortunately between some serious torquing and WD40 I have not yet been able to remove the carrier bolts. Any suggestions on how to do this? Should I try to get a torch back there?
Thanks,
david
Last edited by davidd31415; Sep 26, 2009 at 06:50 PM. Reason: added clarification: front
Davex
Sep 30, 2007 12:42 AM
NYYANKEE
Aug 13, 2007 12:14 PM
cosmo
Sep 29, 2006 02:04 PM
cosmo
Jul 26, 2006 08:22 PM
TruSake
Jun 11, 2006 03:04 AM
