Plugs in frame rail
Old Dec 29, 2008 | 12:36 PM
newhyundaiowner's Avatar
Default Plugs in frame rail
I have read the issue addressed in this fourm not sure if I complelty understood the answer.
When looking at the frame rail I notice a total of 4 holes , there appear to be 2 which are larger
one is at the front of frame rail, the other larger hole is at the rear of frame rail.
There are 2 smaller holes between these 2 larger ones. Looking under my car I see the larger
front hole has a plug, The 2 smaller holes sort of more in the middle of frame rails both have
rubber plugs.
The larger rear hole has no plug, should it have a plug... Thanks
Old Dec 31, 2008 | 03:53 PM
Skrag55's Avatar
Default RE: Plugs in frame rail
These four plug holes are to prevent a wind noise that could occur from under the vehicle. They are usually installed at new car prep. It won't hurt the vehicle not to have these installed.
Old Jan 3, 2009 | 11:14 AM
ken99's Avatar
Everything you should need to know about tie-down plugs:
http://www.hmaservice.com/files/331/1299967/06-80-001pdf.pdf
Non_Affiliated
Oct 31, 2019 07:39 PM
elkarshofy
Nov 24, 2011 11:28 AM
ecy
Oct 14, 2010 04:10 PM
hthoto
Aug 8, 2009 06:33 AM
jimrinflorida
Dec 12, 2008 08:03 PM
