removing antenna from trunk
so my 2002 power antenna has been making a clunking/popping noise for some time, and i think finally died on me. it's stuck in the up position, and i can't force it back to the closed position.
i took the trunk apart, removed the 10 mm nut, the ground wire, the male/female connector, and nearly removed the whole unit but since i can't get the antenna mast to go down, i can't remove it from the car. i tried loosening the 12mm chrome nut but the antenna mast won't budge.
any suggestions? also my dealer wants 176 bucks for a new motor/antenna assembly. anybody good online?
well i found an aftermarket universal power motor and mast for 40 bucks, but until it comes in, i'd like to at least shove the broken mast down a bit. i'd just remove it but then i'd have a hole into the fender/ trunk...
http://www.cardomain.com/ride/242890...-sonata/page-8
Hey everybody. The stock power antenna finally started dying after 10 years, so I did a quick write-up of the aftermarket replacement.
I got it from Hyundai Sonata 96253-38001 Power Antenna Mast 1998-2005, and they ship very quickly. The also have just the mast, or just the gasket, etc.
The tech guy was very helpful too. Highly recommended.
Enjoy!
Enjoy!
mitchlub
Mar 28, 2010 06:38 PM
