Replacing Factory Radio... Mounting kit required?
’02 Sonata
Replacing the factory radio… do I need to get Mounting Kit or will it fit directly into the original spot? And if so, what is the best way to take it out without breaking anything J Thanks all! |
RE: Replacing Factory Radio... Mounting kit required?
And if so, what is the best way to take it out without breaking anything 1. Disconnect the negative(-) battery terminal.[/align] 2. Remove the center facia panel and disconnect the wire connectors.[/align] http://www.hmaservice.com/data/Passe...G/ksmb008l.gif 3. Remove the 4 screws holding the audio unit then remove the audio assembly.[/align] http://www.hmaservice.com/data/Passe...G/ktmb171a.gif 4. Disconnect the power connector and antenna cable jack from the audio unit.[/align] http://www.hmaservice.com/data/Passe...G/etac025a.gif 5. Installation is the reverse of removal.[/align] do I need to get Mounting Kit or will it fit directly into the original spot? |
excellent, the factory radio is the 2" version... so my aftermarket one (which i've had for a year already) should fit perfect.
Thanks for the help! |
