Replacing Factory Radio... Mounting kit required?
Old Dec 17, 2008 | 12:39 PM
Integraoligist's Avatar
Default Replacing Factory Radio... Mounting kit required?
’02 Sonata
Replacing the factory radio… do I need to get Mounting Kit or will it fit directly into the original spot? And if so, what is the best way to take it out without breaking anything J
Thanks all!
Old Dec 17, 2008 | 07:31 PM
ken99's Avatar
Default RE: Replacing Factory Radio... Mounting kit required?
REMOVAL AND INSTALLATION
1. Disconnect the negative(-) battery terminal.[/align]
2. Remove the center facia panel and disconnect the wire connectors.[/align]
3. Remove the 4 screws holding the audio unit then remove the audio assembly.[/align]
4. Disconnect the power connector and antenna cable jack from the audio unit.[/align]
5. Installation is the reverse of removal.[/align]
If you buy the right size head unit, it should fit without any modification. Hyundai offered two different sized factory stereos for this car, a single DIN that fits a 2" opening and a double DIN that fits a 4" opening. You will need to buy a unit that matches the hole (although I think Hyundai does or did sell a cubby hole filler box to put a 2" unit in a 4" hole) and you will need to reuse the factory mounting brackets that are screwed onto the sides of the original unit. An Iso-DIN unit will also fit, but will leave a slight gap around the edge since you will not be using the slip case mounting bracket that comes with the Iso-DIN unit. Buy a unit from a place like Crutchfields and they will make sure that they will sell you astereo that fits.
Old Dec 19, 2008 | 08:23 PM
excellent, the factory radio is the 2" version... so my aftermarket one (which i've had for a year already) should fit perfect.
Thanks for the help!
gjz30075
Sep 18, 2012 09:42 AM
kiwi1124
Apr 29, 2012 07:56 AM
mattman22033
Dec 22, 2010 08:09 PM
YankeesFan5512
May 3, 2009 09:17 PM
Hytech
Mar 5, 2009 08:25 PM
