sante fe wheels on 09 sonata
Old Feb 10, 2009 | 09:04 AM
gsgolf's Avatar
Default sante fe wheels on 09 sonata
I would like to know if wheels from an 06 sante fe will fit on my new 09 sonata. They are 16X6.5 and BOLT PATTERN is 5ON4.50. The size appears to be the same as what's on the Sonatas with alloy wheels, but I'd like to know for sure before I buy them. My new Sonata came with steel wheels and wheel covers. I put snow tires on the steel wheels and have the brand new Michelin tires waiting for some better rims. Any help here would be appreciated.
Old Feb 11, 2009 | 08:13 AM
They shoudl fit with no problems. They have the same bolt pattern and center bore. I replaced the 16" wheels on my 2006 Tucson with 18" wheels from a Hyundai Veracruz with no problems:
I parked next to another Tucson with the original wheels to compare of the 2:
Old Feb 12, 2009 | 08:55 PM
If you haven't purchased those Santa Fe wheels, I have a set of 4 16" Tucson wheels that would also fit:
Old Feb 14, 2009 | 02:57 PM
Personally, I think the 2006 Santa Fe 16" wheels are just OK compared to others.
2006 Sante Fe 16" wheel:
Here are the 2006-08 Tucson 16" wheels I have for sale:
If you don't like them, here are others you could look for that I think look much better:
Azera 16" wheel (my favorite):
2007-up Tiburon 16" wheel:
Old Feb 15, 2009 | 12:30 PM
Rickpt's Avatar
Default Hyundai wheels
I'm going to use a set of 16" Tiburon 03 wheels on my 07 Sonata. I bought them years ago off ebay with three great Michelins for ~ $130. My kind of price.
16x6-1/2 (alloy, 5 spoke). I prefer 16" to 17" for street use, as higher profile tires offer more protection for the wheel & a softer ride. Hitting a bump & destroying a wheel & tire is just too easy with lower profile tires, especially with 50 & below series aspect ratio.
Why do you think all those wheel repair places have started business?
Old Feb 15, 2009 | 02:25 PM
That's just not true. There are plenty of cars that come with 18" and larger tires with 50-series or lower profile tires from the factory.
Here are some of my past and present cars:
2002 Voyager - 17" wheels - 225/60-17 tires - 45,000+ miles = zero problems
2003 Vibe - 17" wheels - 215/50-17 tires - 24,000+ miles = zero problems
2004 Tiburon - 17" wheels 215/45-17 tires - 36,000+ miles = zero problems
2006 Tucson - 18" wheels - 235/50-18 tires - 33,000+ miles = zero problems
2006 Sedona - 17" wheels - 235/60-17 tires - 30,000+ miles = zero problems
That's 168,000 miles on 17" wheels (or larger) with no problems. And that is on Pennsylvanis roads; some of the worst roads in the country.
Old Feb 15, 2009 | 10:04 PM
gsgolf's Avatar
NovaResource,
Give me a price and lets see if we can work out a deal. I just missed an ebay auction thurs. which had the 06 sante fe rims for $159+$80 shipping. As everyone else, i am looking for deals!!!!
Thanks..
Greg
(PS...I dont know if this sort of sales activity is acceptable on this forum. If its not, i apologize in advance!!!)
Old Mar 12, 2009 | 10:16 PM
duaux's Avatar
Question Need Specs Please
ALL:
Nice community forum.
First time poster.
1. I am in the same situation as gsgolf.
2. I have a 2009 Hyundai Sonata with 16'' steel wheels. I bought snow tires and put them on the steels, and I am currently looking for alloys to fit on my factory all-season tires.
3. Can anyone provide the exact specs for the alloy wheels I need please?
All-Season Tire Specs:
Michelin Energy MXV4 S8
215/60R 94V
M+S Tubeless
Radial XSE
GreenX
4. When viewing the different "rim" stores, I get confused with what will fit my tires.
Example A:
Size 16" x 6.5
Bolt Pattern 5x114.3mm
Offset +42mm
Example B:
Size 16" x 7
Bolt Pattern 5x100/114.3mm or 5x110/114.3mm?
Offset +42mm or +40mm?
5. Which one will fit?
6. Can I buy 17'' rims to put on these tires? Or does it have to be 16"?
Any help and or schooling appreciated.
Thanks.
Old Mar 13, 2009 | 12:26 AM
ken99's Avatar
16 x 6.5J with a 5x114 bolt pattern and 46mm offset.
Example A:
Size 16" x 6.5
Offset +42mm
Example B:
Size 16" x 7
Either can be made to work, but example A matches the stock specification better than example B. The smaller offset means the exposed face of the tire will be extended farther from the hub face, providing a slightly wider stance. It looks like example B has a dual bolt pattern.
The tires require a 16" rim. If you want 17" rims, you will need to buy a different set of 17" tires.
I assume the original TPMS sensors are still installed on the steel rims with the snow tires. Any rim you purchase needs to be TPMS sensor capable and you will need to buy a new set of four sensors for the TPMS system to work. The downside to this situation is the sensors on each set of rims will have to be registered with the system (using the TPMS Exciter scantool) each time they are installed on the car. The alternative would be to install the original sensors on the new alloy rims and then live with the TPMS system error light on while driving the car with the snow tires.
Old Mar 13, 2009 | 08:09 AM
duaux's Avatar
Thumbs up Ken99
Ken99,
Thank you for taking your time to explain to a tire newb.
Your information is much appreciated, and I hope it will help others when searching the forums.
1. Can you/anyone else provide some clarification to what the "J" represeents in the stock rims?
Sonata 2009 Stock Rims
"16 x 6.5J with a 5x114 bolt pattern and 46mm offset"
2. Note on TPMS Sensors:
I do not have them on my car.
So I guess I will be saving a bit of money there...
I am in Canada, the stock model does not come with TPMS.
3. Will the tire pressure remain the same? i.e. 32 PSI
Thank you.
