Sonata rear noise- Rear Shock Replacement
Old Apr 30, 2008 | 04:54 PM
  #11
mamamia's Avatar
Default RE: Sonata rear noise- Rear Shock Replacement
does this apply to 2006 sonatas as well
Will this effect the 2007 4 cyl model too?
It applies to ALL 2006 Sonatas but only those with the V6 engines. As to 2007, only the early ones that were assembled before there was a fix. Again, only the V6 version is affected.
Old Nov 22, 2008 | 11:00 PM
  #12
coolbreeze's Avatar
My 2006 4-cylinder had a problem with both sides of the front and rear suspension on more than one occasion. All were replaced under warranty.
Old Nov 24, 2008 | 09:26 AM
  #13
Rdturbulence's Avatar
Hey ED aka stingray69, i love 46 chevy, beautifuly done, i would have chopped the top though,regardless of that,,its simply AWESOME!!!!
Old Dec 3, 2008 | 04:16 PM
  #14
marblehead's Avatar
This problem is not unique to the 09 V6 model, plus I believe it isa front and rear suspension problem or the tires. I just leased an 09 GLS 4cyl. when I test drove a similar model I did not hear or feel this problem. Also, when I took delivery of my car, the tires had an air pressure of 43 PSI. I lowered the pressureto 32PSI, any lower and the TPMS light comes on, which I don't care aboutbecause the car rides better. I had a 10 year old Ford F-150 with 120,000 miles on it that rode better than this car. Except for this problem I like the car alot, but intend to take a run at the dealer. The noise and the jarring ride arereally annoying.I think different tiresmight alsohelp. The car feels like the tires are made of solid rubber.
Old Jan 7, 2009 | 02:18 AM
  #15
airtrafficone's Avatar
GDay from Australia - just bought an early 2007 used Sonata NF V6 here with 30,000 miles. I noticed this clunking so GREAT INFO for me to take to dealership tomorrow! Cheers! Gordon (ex Royal Aussie air Force air traffic controller - Captain)
Old Feb 22, 2009 | 05:30 PM
  #16
Three Sonata Family's Avatar
Smile So when should Sonata shocks and struts be replaced?
I guess this could be a new question but please tell me, what is the normal life of shocks and struts on Sonata's? I have nearly 75000 on my Sonata and it drives just fine. I have been having the tires rotated and balanced as well as alignment etc. What do you think?
Old Mar 25, 2009 | 10:52 AM
  #17
Sonata06GLSV6's Avatar
I would expect at least 100k out of them. When they go I'd seriously think of upgrading to SE suspension components for better handling (shocks and struts). I plan on doing that if I keep the car much past 100k. (Awhile for me since I only have 43k now)
Old Sep 22, 2009 | 02:17 AM
  #18
timber.link's Avatar
Well nice for these posts it would help many users of sonata but one thing more the noise is not only from its shock but many a times the fuel tank also makes a hell lot of noise.
Old Oct 27, 2009 | 10:38 PM
  #19
matsonv6's Avatar
Thumbs down
does this shock prob occur on australian model sonatas
Old Mar 6, 2010 | 11:07 PM
  #20
Originally Posted by marblehead
The noise and the jarring ride arereally annoying.I think different tires might alsohelp. The car feels like the tires are made of solid rubber.
I bet the car is equipped with "V" rated tires... add in some high pressure gas shocks, and firm springs.... firm ride.. just like a childs little red wagon over the cracks in the sidewalk..
You could put some lower speed rated tires on it, but then the handling may suffer..
