stalling
Old May 7, 2009 | 04:05 PM
gussetgus's Avatar
Default stalling
03 sonata 2.4 stalls after driving a short time then will start but stalls as soon as you hit the gas. If you wait like 5 min it is fine and drives ok. 2 codes come up a po102 maf circuit low input. p0335 crankshaft position sensor a malfunction. I replaced the crank sensor last summer. Is there any way to make sure they are bad or do i have to change them both, a couple hundred doller hit to the wallet. or could one of them be bad and causing the other to throw a code?
Old May 7, 2009 | 05:06 PM
jsinton's Avatar
Banned
The MAF is probably the culprit, it shouldn't effect the crankshaft position sensor. A MAF can cost $200 to $300, but it's easy to put in. Is this a recent code scan? You can look for intake leaks, this would give you the same MAF code, maybe some broken rubber?
Old May 7, 2009 | 06:47 PM
gussetgus's Avatar
Smile
Yeah read it this afternoon. Ill ck the vacume lines before spending the money on the maf. Just hate to spend that kind of money and then still have the same problem. I took the maf out yesterday and used some maf cleaner on it hoping that was it but of course it wasn't
gail
Dec 22, 2006 11:21 AM
gail
Oct 29, 2006 07:43 PM
Stacey98Tib
Sep 30, 2006 08:41 PM
slider_535
Mar 14, 2006 11:42 PM
syrup1
Nov 8, 2005 09:13 PM
