Thinking about changing my own fluids in an 07
I am considering changing the transmission fluid my 07 GLS automatic Sonata. It has 64K and Firestone wants about $170. I also hope i could get a coolant flush and a break flush while I am under there (quoted at about $180.)
I was wondering if anyone has done one of the three in the past and could give me some tips. I plan on buying Jack stands to make my life easier. What do you guys think? |
Unless you know what you are doing and/or have someone there that does to help you, I wouldn't suggest doing this. Especially the trans fluid and the brake fluid. $180 to flush those fluids isn't a bad price. Also, be sure whoever changes you transmission fluid uses ONLY SP-III fluid from Hyundai. All other trans fluids will destroy your transmission.
I have a 08 sonata and did the trans fluid change myself at 30k. Tranny drain plug makes it as easy as an oil change. I used the Hyundai tranny fluid. Do it your self and save $$$.
That drain plug drains less than half the fluid.
(Post 38394)
That doesn't guarantee you get out the other half. Half the oil you drained out the second time was the new oil.
(Post 28680)
No, that won't work because it's only getting out what's in the pan (just like draining the pan would do). The problem is getting out the fluid in the valve body and torque converter.
Pros have 2 types of machines. One disconnects a line from the radiator and connects it to the fluid transfer machine. A line on the machine connects back to the radiator. Then they run the engine and the trans pump pushes the fluid out into the machine while the machine pushes new fluid back in. The other type of machine attaches to the pump intake after the pan and filter is removed. This machine only supplies fresh new fluid to the pump intake and as the fluid passes through the transmission it dumps out to a collection tray and never goes back through for a second pass. All of the old fluid and crud is replaced with fresh new fluid. After the service a new filter is installed, the pan replaced and then it is topped off with new fluid to the proper level on the dipstick. |
