What happened to the TSB thread?
Back when I was deployed late last year (just returned), I thought there was a thread listing all of the TSB's and all that. Specifically, there was one for the Navigation update. Anybody know what happened to it?
No, that wasn't it. Hmm...
What yr and model ??
I have a dealer login and can probably tell you if anything applicable... |
2011 Sonata Limited w/Nav
3 Attachment(s)
There was a NAV update offered for dealer stock only... There was a handfull leaked out by fella that operates another forum.
In the end, dealer person needs to have VIN, and hardware number, login into to vendor site with all the info, and if applicable, it will give code to allow you to proceed.. I did maybe 10 or so of our cars.. Send me your VIN, and device ID number, I'll see if it they will generate code for your VIN... they pretty well know what cars were still in stock and what was out on road.. I can burn a DVD of the update, you then put it on a 8G stick, then put stick in the USB port, and walk the walk to get ti up and running.. BE ADVISED -- car has to sit and idle for approx 1hr while update runs.. start program, verify it goes, and DO NOT DISTURB the car till done . https://www.hyundaiforum.com/forum/a...1&d=1298602096 https://www.hyundaiforum.com/forum/a...1&d=1298602096 https://www.hyundaiforum.com/forum/a...1&d=1298602096 |
Sweet. I'll send you the info when I get home from work today. Thank you.
