when to change plugs & wires
Old Feb 5, 2009 | 01:31 AM
avocational driver's Avatar
Default when to change plugs & wires
I now own a 2002 Sonata with 80K miles. Is it time to change spark plugs and wires? I think the car still has the original plugs and wires. Any advice would be appreciated. Thanks.
Old Feb 5, 2009 | 05:10 AM
jsinton's Avatar
Banned
The are supposed to be good for 100k. It wouldn't hurt to pull a plug and see how they are doing. Also, wires don't wear out like in the old days. You probably don't need to change anything. They are supposed to be platinum plugs. Did you change the timing belt?
Old Feb 5, 2009 | 08:26 AM
Yes, the previous owner changed the timing belt at 60K. He opted out of the other services offered at 60K, but did the most important thing, the timing belt. Is there anything else I should consider doing, or inspect, at this point, since the car is at 80K?
Thank you very much for the info about the spark plugs.
Old Feb 5, 2009 | 03:31 PM
jsinton's Avatar
Banned
If you just want to be sure, you could change the air filter, the fuel filter, and do a trans flush and a coolant flush.
Old Feb 15, 2009 | 10:35 AM
frankcarparts's Avatar
Yeah! you must change air filter, fuel filter and coolant flush.
ceartly
Oct 14, 2008 10:52 PM
anonymouse
Apr 14, 2008 09:36 AM
scd942
Jan 4, 2008 04:03 PM
ConradRacing
Aug 16, 2007 06:46 PM
ModelPOS
Jan 26, 2006 03:51 PM
