is the 03-05 Tiburon Headlights interchangable with the 06-? Tiburon?
I have an '03 Tiburon and I want to know are the Headlights interchangeable from an '06 Tiburon? I like smooth finish of the '06's headlights instead of my '03's.
RE: is the 03-05 Tiburon Headlights interchangable with the 06-? Tiburon?
I have an '03 Tiburon and I want to know are the Headlights interchangeable from an '06 Tiburon? |
The 2005-06 headlights lights will physically fit but the wiring harness is slightly different. However, it's not hard to modify if you really want the 2005-06 versions and I believe there is a conversion harness available now. So, yes, it can be done.
More info: http://www.newtiburon.com/forums/showthread.php?t=40681 http://www.evofusionusa.com/TeamSR/H...stallation.jpg Conversion wiring harness: http://www.tuscanidiys.com/ledstuff/...e/100_9384.JPG http://www.diodedynamics.com/catalog...roducts_id=103 |
Should they be converted in pairs?
I don't understand the question? What pairs? Left and right? It would look kinda dumb if he has a 2003-04 headlight on one side and a 2005-6 headlight on the other.
It would look kinda dumb if he has a 2003-04 headlight on one side and a 2005-6 headlight on the other. |
