98 tibby front wheel brg replacement
I am about to remove the front spindle assemble to replace a bad wheel bearing. I read the Chilton's manual and see it requires special tools.
I have access to a hydraulic press,but don't have any special tools for handling,pressing. Any suggestions as to whether I should take it to a shop or attempt to do myself. I'm also going to replace the rotor,since it is wornout. Appreciate any suggestion,ideas, Tom |
You have to separate the ball joint, you need a tool for that. You've already got a press. All that's left is knowing how to use it. Up to you whether or not you're comfortable doing it.
Tibby wheel bearing
Thanx for your imput. I was concerned with how I was going to hold unit in press,and since I didn't have any of the specialty tools listed in manual. I guess I'll find out,when I get it out of car. Tom
1 Attachment(s)
It's really not that hard. Let us know how you make out. Good luck.
