alarm question
I have a 2003. Is it possible to simply open the door using the key and somehow shut off the alarm without using the FOB? Our situation is if I loose my keys I have a spare in my wallet but no FOB.
Suggestions?
Suggestions?
Suggestions?
"Alarm Stage
The alarm will be activated if any of the following
occur while the car is parked and the system
is armed.
1) A front door is opened without using the key
or the transmitter.
2) The tail gate is opened without using the
key.
3) The engine hood is opened."
Using the key is cool with the alarm system. If you have doubts, you can always test your wallet key while the car is sitting in your drive way.
Thanks for the reply Ken but the alarm DOES go off when I open the driver's door with the key.
"Only the transmitter can disarm the armed stage. If the transmitter does not disarm the
system, it is necessary to take the following steps;
1. Unlock the door with the key, which will cause the alarm to be activated.
2. Insert the key in the ignition key cylinder and turn the ignition key to "ON" position.
3. Wait for 30 seconds.
After completing the steps above, the system will be disarmed."
It sounds like the alarm is operating as designed. I can only suggest you never loose the fobs.
Ken
The car is used so I don't have a manual
ORIGINAL: ken99
Capricho - I owe you an apology. I just opened the owner's manual file I downloaded last night to review the discussion on the alarm system and discovered none of the verbeage I cited could be found in the book. I must have inadvertantly open the 2008 manual file to my car. The discussion I found in the correct manual states:
Ken
Ken
