Drivers side window 01 Tiburon
Old Dec 10, 2005 | 12:00 AM
PATIBBY's Avatar
Default Drivers side window 01 Tiburon
My daughter broken here drivers window regulator today with snow and ice on the glass. Has anyone changed one of these? What involved? Does the new one come with the motor attached? Thanks. 2001 Tiburon
Old Dec 22, 2005 | 08:20 AM
tiburonmoo's Avatar
Default RE: Drivers side window 01 Tiburon
It's not a hard thing to replace. Naturally you will have to remove the door panel first and from there it's pretty easy. Just one thing for you to know though is that the screws at the bottom of the panel do NOT need to be removed as they only hold the map pocket on and will not stop you from removing the panel itself. Hit up car-parts.com to get a used one would be my suggestion b/c as we all know dealers will rape you. Maybe you might want to consider hitting up the WANTED section at rdtiburon.com to see if someone has one available.
Old Dec 22, 2005 | 02:30 PM
Patrick's Avatar
Administrator
also, a friend of mine wrecked his, and found parts in junkyards for MUCH cheaper than the stealership
Old Dec 25, 2005 | 02:38 PM
PATIBBY's Avatar
I fixed it . found the part at Bowser Hyundia that Saturday and picked it up and in about an hour was back on the road. I paid about 130.00 for the part. All is well now. I just have to replace the timing belt now. How much of a job is that?
Old Jan 6, 2006 | 06:04 AM
tiburonmoo's Avatar
Well, if you have to ask then get someone to do it for you. It's from $200-$300 if I remember right or that might have been for a wheel bearing.
COhe2000
Apr 28, 2011 05:08 PM
Integraoligist
Mar 17, 2009 09:45 PM
tiBuronGt
Jan 11, 2009 02:31 PM
tonto555
Sep 17, 2008 03:17 PM
tduncan
Jan 16, 2007 12:44 AM
