Electrical Issue...i need all the help i can get
OK so my friend has a 2003 Tiburon GT with the infinity sound system....we tried to install a new aftermarket radio today and while we were taking the wire clips out of the back of the stock radio we saw a small spark....we didnt think anything of it...and we went ahead and wired the new wire harness and the aftermarket radio harness. we go and put everything back together and test out that we did the wiring correcty and try to power up the new radio and we get nothing...so we try a few things and nothing is working we check the fuses and nothing either...so we go and put back the stock radio and that wont even power on now...then we later realized that his dome lights are not working...power locks are not working and neither is the alarm and harzards when the car is off...is there a central fuse that controls all of the interior things that is connected to the radio...what could it be...short mabye....please help asap...this is not my car this for a friend of mine...hes not happy..haha
Also check fuse #2 labeled "AMP". Unlike the other two fuses, I don't think any other systems are shared with fuse #2 but you will not have sound if the amplifier fuse is blown as well.
what about that yellow looking fuses in the interior fuse box
[IMG]local://upfiles/4972/21990E6D35A74321A14F71D000076514.jpg[/IMG]
P.S. Make sure you replace the fuses with ones of proper amperage rating. ROOM LP and AUDIO take 10A fuse (which should be red), AMP takes a 20A fuse (which I think is yellow).
CLG_02
Aug 6, 2010 02:29 AM
rokuez
May 1, 2008 06:10 PM
