Electrical Problem
Old Feb 23, 2009 | 08:53 AM
allegrettim's Avatar
Default Electrical Problem
My daughter has a 03 Tiburon. She purchased a radio faceplate to replace the Infinity one that was not showing digital channels. It was installed by a friend of hers. After it was done some of the dash lights and lights for the console do not work. Also her right rear light is out. Anything I can look at? Fuses?
Thanks
Mike Allegretti
Old Feb 28, 2009 | 08:58 AM
mattsaari's Avatar
If they did not use the correct wiring adapter i would check the stereo wiring its possable they hooked the ground up to the high beam becuase when high beams are off its a ground bukt then hot when high beams are hit so i would check this and look at the fuses may be blown
jkang
Nov 19, 2008 12:48 AM
dmnchld
Mar 9, 2008 12:26 PM
n6szc
Nov 21, 2007 07:30 PM
novapool
Apr 1, 2007 05:49 PM
senso
Nov 24, 2006 10:16 PM
