First Time Engine Swapper in need of help
This is my very first engine swap for any car. The current engine is busted and just need to get a dependable car going for a family member (Not build a rocket)
2003 Tiburon I-4 I will be ordering engine/trans soon and the description is as follows: Gas Engine, Complete Unit 2.0, Without-CVVT, Automatic Transmission, FWD, RIV-RG ---------------------------------------------------------------------------- How do I find out if the current setup has "CVVT". Will my replacement engine necessarily need to have the variable valve timing? Do engines typically come with the computer? Will I need special pullers/wrenches? I do have an engine hoist and basic sockets,end-wrenches,etc. Also am pretty good with a wrench. (Just never did a complete swap before) Any help much appreciated. Thanks |
'Check Engine' light but NO ODB2 codes.
2003, 2.0L, Auto Trans, about 100K mi on a replacement engine.
The 'Check Engine' dash light comes on but when I hook up the ODBII scanner there are no codes being thrown. I did replace the engine/trans myself and everything else is fine and I don't see any loose wires/connections nor loose vacuum lines and I've gone over it with a fine tooth comb. Any ideas appreciated. |
