install a turbo on tibby oil problem!!! help!
hey Guys!!
i just found out about this web site hopefuly someone can help me..I installed a Turbo on my tibby not to long ago and, ibeen having problems with my oil pressure.(I think it's my oil pressure?) the oil dip stick has been popingoutevery time i go more then 5-6RPM(meaning when iam hauling ass from a stop light) i think that my turbo pressure is to high or i need some think(part) to release pressure from the engine,if any bodyknow's some part for my car thatcan fix that please info me. if you think its a simple adjustment please let me know.. Thanks Guys... peace..:( |
RE: install a turbo on tibby oil problem!!! help!
Are you using any boost controller?
How much psi are you boosting? Is it tuned? What turbo and supporting mods? Kinda sounds like excessive crankcase pressure, but with just a little more info and I can help you moreman. |
hey i found out the problem!!!! my PSI was way to high.. i was pushing 15 psi and took it down to 8psi.. runs like new.... but dose any one know how to keep my temp down from the manufold pipes. you know to keep the heatlowunder my hood. hit me up for any ideas.. thanks.
if you are using a S.S. turbo manifold, buy some wraps for it, it usually helps quite a bit, but only use the wraps if you're manifold is S.S. otherwise it will eventually rott the manifold.
