Need a little help
Hi, I'm not sure anyone will even read this or reply to it...
Well I have a Hyundai Tiburon 2000 5 speed.....I'm changing the clutch is there a website that I look at to see the steps on how to do it... I'm started taking it out.... I've done everything thing its turned on its side, and there is a 2 inch gap going around it..... What do I need to do to take the clutch out so i may replace it... |
Did you take off the controller push arm? It's not listed in the general instructions, but if you don't take it off, you can't remove the trans without destroying the clutch.
Umm... not much of a car person... but what dose it look like?
The controller arm that actuates the clutch. The slave cylinder pushes it. You need to remove it so that the shaft it connects to can rotate enough to free the bearing forks from the throwout bearing. Otherwise the fork will hold the transmission to the clutch plate.
Just remove the one bolt from the controller arm and pull off the arm. |
Yea, I have that off...
Let me explain more... I have at a twist, it has about a two inch gap going around it... I hope that can help more tomorrow when I get off I will take some pictures to show, maybe that can help some |
Photos would help a lot.
Sorry for the long wait... been kinda busy :confused:
so will they help you outhttp://c2.ac-images.myspacecdn.com/images02/79/l_2392daf43ef7418daf272938a104e391.jpg http://c3.ac-images.myspacecdn.com/i...65dec4e86a.jpg http://c1.ac-images.myspacecdn.com/i...e7a067da00.jpg http://c3.ac-images.myspacecdn.com/i...d7f5790366.jpg http://c4.ac-images.myspacecdn.com/i...1c6614d51f.jpg sorry for the small pictures I tried fixing them, but there was nothing I could do... you can look on myspace for a bigger picture.. Timotheus08@yahoo.com |
Sorry to say... YOU'RE DOING IT ALL WRONG!
You've unbolted the two halves of the transmission case. That's not where the clutch is. The clutch is BETWEEN THE ENGINE AND THE TRANSMISSION! YOU DIDN"T WANT TO BREAK THE TRANSMISSION CASE OPEN! I'm not so sure you didn't render you're transmission useless. I'll try to find some instructions. Big "E" for effort, otherwise not so good. |
So? ummm? what can I do? can I put the 2nd half together? or am I screwed?:(
